az_uk
Sep 02, 2020Aspirant
System: Bond interface bond0 has slave interface eth1 offline.
I am running a ReadyNas 202 with firmware 6.10.3 connected to a netgear 16 point switch and then connected to Virgin Media router. My laptop is connected to the router through ethernet. I have just run speedtest.net and have 239Mbps down and 20.77Mbps up speeds.
I have been getting regular errors shoing up on the logs.
| Sep 02, 2020 07:54:28 AM | System: Alert message failed to send. | |
| Sep 02, 2020 07:54:28 AM | System: Bond interface bond0 has slave interface eth1 offline. | |
| Sep 02, 2020 07:54:27 AM | System: ReadyNASOS background service started. | |
| Sep 02, 2020 07:54:18 AM | System: ReadyNASOS service or process (snapshot_monito) was restarted. | |
| Sep 01, 2020 07:53:26 AM | System: Antivirus scanner definition file was updated to 59.25916. | |
| Aug 31, 2020 07:52:28 AM | System: Alert message failed to send. | |
| Aug 31, 2020 07:52:28 AM | System: Bond interface bond0 has slave interface eth1 offline. | |
| Aug 31, 2020 07:52:27 AM | System: ReadyNASOS background service started. | |
| Aug 31, 2020 07:52:18 AM | System: ReadyNASOS service or process (enclosure_monit) was restarted. | |
| Aug 31, 2020 12:05:22 AM | Backup: Error backup job Doc BB to 88: Failure during copy. | |
| Aug 30, 2020 07:51:00 AM | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. | |
| Aug 30, 2020 12:05:18 AM | Backup: Error backup job Pic backup: Failure during copy. | |
| Aug 29, 2020 07:50:48 AM | System: Antivirus scanner definition file update failed due to download failure. Check your Internet connection. |
I have added in colours as per the logs.
Please help.
az_uk wrote:
How do I take this feature off?
Just click on the settings wheel next to bond0, and select "delete".
