az_uk
Sep 02, 2020Aspirant
System: Bond interface bond0 has slave interface eth1 offline.
I am running a ReadyNas 202 with firmware 6.10.3 connected to a netgear 16 point switch and then connected to Virgin Media router. My laptop is connected to the router through ethernet. I have just r...
az_uk
To add, I have 2xWD Red 6TB hard drives
Sep 02, 2020Guru - Experienced User
Did you set up your NAS network interface to use bonding (also called link aggregation)?
- az_ukSep 02, 2020Aspirant
I think I do - although I don't think there should be as my switch doesn't support Link Aggregation. How do I take this feature off?
Thanks so much for your quick response!
