Michael_Oz's avatar
Michael_Oz
Luminary
Dec 22, 2019
RN316 - backup log "does not have detail log when volume is in read-only mode"
I just did a backup, it completed, but the log says
Backup Start Time: Mon 2019 Dec 23 10:05:37
Backup Finish Time: Mon 2019 Dec 23 13:03:49
Backup Status: Success
-------- Backup Job Log --------
Backup job does not have detail log when volume is in read-only mode.
I checked the admin page and every thing looks normal.
I can read/write/delete files on shares, so it is not read-only.
  • StephenB's avatar
    New one for me.  I am wondering if the OS volume might be in read-only mode.  Did you try downloading the full log zip file?
    • Michael_Oz's avatar
      Michael_Oz
      Luminary
      Dec 23 10:05:32 RN316A fvbackup-q[5184]: write(/var/log/frontview/backup/status_backup_009,BACKUP_STATUS__IN_QUEUE!!1577055932!!OK)
      Dec 23 10:05:32 RN316A fvbackup-q[5184]: Push: job_id=9 q_wp=20 q_rp=20
      Dec 23 10:05:37 RN316A fvbackup-q[5184]: cmd=/frontview/bin/fvbackup -e 9
      Dec 23 10:05:37 RN316A fvbackup-q[5184]: fvbackup.c:1106 (error) mkdir(/apps/.backup/) failed.
      Dec 23 10:05:37 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95
      Dec 23 10:05:37 RN316A fvbackup-q[5184]: mount error(95): Operation not supported
      Dec 23 10:05:37 RN316A fvbackup-q[5184]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      Dec 23 10:05:38 RN316A kernel: CIFS VFS: cifs_mount failed w/return code = -95
      Dec 23 10:05:38 RN316A fvbackup-q[5184]: mount error(95): Operation not supported
      Dec 23 10:05:38 RN316A fvbackup-q[5184]: Refer to the mount.cifs(8) manual page (e.g. man mount.cifs)
      Dec 23 10:06:01 RN316A cron[6609]: (*system*frontview-backup) RELOAD (/etc/cron.d/frontview-backup)
      Dec 23 13:03:49 RN316A readynasd[16716]: Successfully completed backup job MePC D VMs.
      Where does that live?
      I'll try rebooting.
      • StephenB's avatar
        /apps is a mount point on the OS partition that normally mounts /data/.apps
        Rebooting is a reaonsable idea.
ProSupport for Business
