mrg_arg's avatar
mrg_arg
RN316 - problems after 6.7.4 - not booting
I upgraded to 6.7.4 a few days ago, and shut the system down a couple days after that.  When I tried to reboot, I got "mount_block_root +1f1" error.   I found discussion about fixing that with USB recovery and latest 6.7.4 - "RN516 "mount_block_root + 1f1" after os 6.7.3 update" I built the usb, and booted  it, and let it run until it shutdown.
After that, when I try to boot, the system hangs at "booting" message.  Pressing reset at boot also hangs at "booting", so I cannot get to menu to restore system.
I saw todays discussion about the RN314 that would not boot (RN312 major problems after 6.7.4 - will not boot) where the fix involved using custom initrd and kernel.  I built that USB recovery, but that seems to boot to where the NAS is in a diagnostic mode, and I cannot login via raidar or telnet - it does not accept my admin password.
Any advice on how to get back to where I can restore or reset the firmware would be appreciated.  I have a backup, if I need to restore entire system - I just need to get to where system will perform the actions.
ProSupport for Business
