Platypus69
Apr 05, 2017Luminary
RN316 | Blinking Red Light for HDD1 | Everything looks fine otherwise
Hi all, It seems that my RN316 had "hung", so I was forced to reboot it. (I have noticed in past couple of months that it waits a long time around 28% during boot process.) Anyway, I rebooted...
- Apr 06, 2017
Is it any better now? Moved your MySQL database to the data volume and created a symlink. Also updated your system to 6.7.0
mdgm-ntgr
Apr 05, 2017NETGEAR Employee Retired
I've sent you a PM.
- mdgm-ntgrApr 06, 2017NETGEAR Employee Retired
- Platypus69Apr 06, 2017Luminary
Huh???
Thoroughly confused although happy :catlol:
Um, so the top HDD is now "back to normal" - blue.
So what has MySQL go to do with anything here. Is it used internally by the RN316
So firmware is saying 6.7. Also saying that DropBox has been updated and I need to re-authenticate. (FYI: I am surprised about the 6.7 update, becuase the admin console never said it wa available and kept saying that 6.6.2 was the latest version.)
Ahhh... is MySQL being used by Plex???
So:
- Is the disk fine?
- Is the firware / NAS fine?
- How do I avoid this?
Thanks a million mdgm,!!!
PS: Can I turn off the "support mode"?
- StephenBApr 06, 2017Guru - Experienced User
Platypus69 wrote:
Is it [MySQL] used internally by the RN316 is ... MySQL being used by Plex???It is not used internally. Plex uses SQLlite (I think) and it's files are kept in /apps (which is on the data volume).
Do you (or did you) install other apps? PHP packages perhaps?
