nybblesandbytes
Oct 20, 2015Star
RN316 randomly freezing shared folder on 6.4.0
Hi, I upgraded a client's RN316 to firmware 6.4.0 about 2 days ago. The firmware update reported successful and all seemed ok for about half a day. Now the primary share (2.7TB) of data, has becom...
- Oct 21, 2015
Do you have ssh enabled? If so, can you go in and run top to see if "[btrfs-cleaner]" shows up and is using lots of CPU? If so, then you may well be experiencing an issue that's been reported in other threads.
BennyKind
Oct 22, 2015Guide
Hi nybblesandbytes
I am curious to know whether you were able to get on to the web interface for your 316?
I am having a similar issue but I cant get on to the web interface to be able to delete snapshots/disable the snapshot schedule. Mine is also incredibly full so I am hoping this will be a fix if I can get on to it to delete snapshots.
nybblesandbytes
Oct 22, 2015Star
BennyKind Web interface is fine - occasionally it freezes up for a few minutes, but it comes right after a while.
After I deleted some snapshots things seemed to improve a bit, but we went ahead and got an extra 4TB drive today.
I have just installed it and it is resyncing - estimated time to resync is 25 hours, so will likely finish sometime tomorrow.
I will be sure to report back after the storage has been expanded.
- Jan 17, 2024Retired_Member
