nybblesandbytes
Oct 20, 2015Star
RN316 randomly freezing shared folder on 6.4.0
Hi, I upgraded a client's RN316 to firmware 6.4.0 about 2 days ago. The firmware update reported successful and all seemed ok for about half a day. Now the primary share (2.7TB) of data, has becom...
- Oct 21, 2015
Do you have ssh enabled? If so, can you go in and run top to see if "[btrfs-cleaner]" shows up and is using lots of CPU? If so, then you may well be experiencing an issue that's been reported in other threads.
nybblesandbytes
Oct 21, 2015Star
So after another day of troubleshooting, I have what I hope is some good news.
Netgear Support came back to me today after I sent them the full device logs this morning.
They noted something very obvious - my data volume is 90% full, and therefore very much in the red. Apparently they recommend that users stay under 80% for optimal operation.
I then went in and deleted some old snapshots and anything redundant, freeing up almost 100GB in the process.
I have to say that since then, I am cautiously optimistic as all users seemed to be stable at close of business.
I am busy monitoring the device remotely and will continue to do so tomorrow morning, and then report back... and then put an additional drive in of course!
KenD90027- how full is your RN316...?
KenD90027
Oct 22, 2015Tutor
Problem remains on my RN314, unable to access admin page to delete snapshots. Was at 90% of 3.5TB nybblesandbytes .
So far I have performed a successful usb recovery for the 6.4.0 and then successfully ran an OS recovery through the boot menu. After rebooting, the unit has an active activity light for several minutes while the LCD shows "Booting..." . Shares are available on the network during that time. Then at some point the shares lose accessibilty and the activity light goes dark. Suggestions anyone? mdgm-ntgr?
- BennyKindOct 23, 2015Guide
KenD90027 have you made any progress on this?
I managed to get on to the admin page for about 10 minutes, deleted maybe half the snapshots before it kicked me off again and now again I am unable to connect to admin page or access the folders.
Becoming a real big problem for us now.
- nybblesandbytesOct 23, 2015Star
Update as at 18:00 today - the extra 4TB hard drive finished resyncing and I now have over 4TB free space available.
The client has closed for the weekend so I don't have any feedback since then, however I will be taking this up again on Monday morning, to establish if the device is now 100% stable again, and performing normally.
Netgear's official position on this was that the ReadyNAS should have 20% - 25% free space available...
- nybblesandbytesOct 26, 2015Star
Update on Monday morning 26 October 2015:
- NAS is running normally at the moment, after upgrading storage with an additional 4TB last Thursday.
The resync took over 24 hours to complete, but it did finish and the shares were up the whole time.
- Netgear had advised me to run a Balance as well. I first ran a full backup on Saturday, and then I started a balance on Sunday morning.
Bad idea - the balance started out fine, showing up progress as 1% initially, then the device locked up completely (no web interface, no shares available, no ping response).
I decided to wait it out until this morning - still dead, so I had someone onsite pull the power plug on the NAS and switch it back on.
After about 5 minutes the NAS came back up, and the web interface showed the balance had restarted at 0% - there is no way to cancel the balance from within the web interface.
I then used PUTTY to SSH into the device and used the following command to stop the balance:
btrfs fi balance cancel /data
It took a few minutes to cancel, but updating the web interface showed that the balance had been cancelled.
Now the NAS is running normally again, and shares are available. I am just concerned about the fact that I had to cancel the Balance - what effect can this have had on the data?
I can't have the device locking up every time I need to run a balance / defrag / scrub...
- nybblesandbytesOct 29, 2015Star
BennyKind Apparently what happens is that after snapshots are deleted, the btrfs-cleaner process is invoked, which is when all hell breaks loose and it consumes 90+% of CPU resources...
For some reason this is delayed - my snapshots were auto deleting at 17 mins past the hour, and the ReadyNAS would freeze at half past, even though the device logs indicated 17 mins past the hour.
I managed to stop the btrfs-cleaner process in SSH and the device seems to working normally again now - LAN shares, web interface.
The only thing I see is that under Volumes, it now only shows "Free Space" and "Snapshots" - no data... Worrying!
Even so, my shares are there and fully accessible and I have a working fileserver again.
Really hoping that Netgear takes note and pushes out a stable fix for this very soon.
- BennyKindOct 29, 2015Guide
nybblesandbytes this is all such a pain in the ****
I managed to get on to the web interface for a good ten minutes and managed to delete all remianing snapshots and change the snapshot schedule to never.
This seems to have fixed it for now despite the unit not taking snapshots which makes me a little nervous. 4 days on and its still running ok and is accessible by everyone.
Netgear really do need to get this sorted.
- Jan 17, 2024Anonymous
