ITisTheLaw
May 14, 2017Guide
RN3220 / RN4200 Crippling iSCSI Write Performance
I've got a mixed OEM ecosystem with several Tier 2 RN3220's and RN4200's along with Tier 1 EqualLogic storage appliances. All ReadyNAS appliances have 12 drive compliments Seagate Enterprise 4TB ...
ITisTheLaw
Oct 27, 2017Guide
So to clarify after the above replies:
- I'm ONLY using fixed size LUN's on the RN's
- I've tried both fixed and dynamic VHDX's, there's virtually nothing between them stat wise
- Sync writes are disabled
- Copy on write isn't used anywhere
- I agree, you should never team iSCSI, that's page 1 stuff. I've tested with single channel or MPIO in dual channel
Based on the previous comment on RAM from nxtgen, I pulled some DDR3 1866 dimm's from a server temporarily and replaced the DDR3 1600 dimm's. The initial test set it to 12GB, single channel due to 3 dimms.
The second to 16GB, all dimm's identical, dual channel
This is the RAID6 array again, with nothing else on it, still running 6.9.0 and local iSCSI, not CSVL. I repeated the test with MPIO on and off. Writes get dented slightly in no MPIO mode, but that 4MB sequential number just won't move up on these arrays.
As you can see, a whole lot of nada. Running top in SSH shown that with enough activity, the system will claim the full amount for cache, leaving about 400MB free every time.
Rebooting the NAS, booting the VM and running Anvil, leave the NAS with about 4.4GB RAM used and the rest free.
I didn't screen shot it, but I put the array down to 4GB RAM, single channel and ran it again. The numbers were identical! No difference!!!
Copy a file to them over SMB or NFS and the arrays will saturate the link(s), no issues there. It's purely the iSCSI.
ITisTheLaw
Nov 13, 2017Guide
Now that we've got the 1GbE write up to par (remember we started with 34MB/s, I've gone back to the 10GbE.
RAID6 array, 1x10GbE on TwinAx DAC, local, not CSVL (CSV doesn't work still)
It isn't anywhere near touching the 7200 x12 QNAP, and the write's are still way down, but it is better than it was.
