Garet's avatar
Garet
RN4220 and SNMP connected UPS
I have a readynas 4220 running firmware 6.4.0. It is connected to a network enabled UPS. ( APC Symmetra LX 8000 RM ) I am polling the UPS with SNMP v1.
I am getting " System: Error communicating with UPS 'Symetra' () " then 10 sec later " System: Communication with UPS 'Symetra' () is OK. "
This runs in spurts. Quiet for a few hours, then 16 in about 2 hours of time. The UPS is not logging any alerts or error activity.
Is this a proven connection method with a UPS? Or a feature that is not used much or is troublesome?
I have 3 network connections running to the switch. 1g and 10g copper. Should not be a bandwidth issue.
Garet
  • JennC's avatar
    JennC
    NETGEAR Employee Retired
    Hello Garet,
    Did you upgrade the firmware just recently and got this problem or you already are experiencing this even on previous FW versions?
    • Garet's avatar
      Garet
      I did not have it setup with the previous firmware. The current level is 6.4.0.
      I did bond 2 10g network connections to the switch. But it did not change anything.
      Garet
      • JennC's avatar
        JennC
        Hello Garet,
        Have you tried another USB port on the NAS? It may be possible it is the USB port where the UPS is connected stops detecting anything plugged in to it.
ProSupport for Business
