r00b's avatar
r00b
RN428 - Waiting for encryption key but no encrypted volumes available
Hi together,   some time ago I had an issue with my encrypted drives (encryption key wasn't found although it was on the pen drive). As a result I deleted all volumes and created new ones without e...
  • r00b's avatar
    r00b
    Aug 11, 2020
    Hi together,
    I could fix the issue by doing the following steps:
    - check systemd-journal.log to see which volume is causing the problem
    - delete volume
    - create new volume with the same name and encryption enabled
    - delete new volume
    - create new volume with the same name without encryption
    (probably it's not necessary but I've done a reboot between each step)
    Now the system boots up without asking for an ecryption key.
    BR,
    Robert
ProSupport for Business
