r00b
Aug 05, 2020Aspirant
RN428 - Waiting for encryption key but no encrypted volumes available
Hi together, some time ago I had an issue with my encrypted drives (encryption key wasn't found although it was on the pen drive). As a result I deleted all volumes and created new ones without e...
- Aug 11, 2020
Hi together,
I could fix the issue by doing the following steps:
- check systemd-journal.log to see which volume is causing the problem
- delete volume
- create new volume with the same name and encryption enabled
- delete new volume
- create new volume with the same name without encryption
(probably it's not necessary but I've done a reboot between each step)
Now the system boots up without asking for an ecryption key.
BR,
Robert
Aug 11, 2020Guru - Experienced User
Since there is no data on the NAS, it's probably fastest to do a factory reset (clicking the "Perform Factory Default" control on system->settings->update ). Then just set up the NAS again.
r00b
Aug 11, 2020Aspirant
Hi together,
- delete volume
- delete new volume
BR,
Robert
- SandsharkAug 12, 2020Sensei
For the benetit of others, and Netwear if they find this is a bug, was there anything different in the way you deleted the re-created encrypted volume than the way you originally did it other than the fact that the encryption key for it was now available?
- r00bAug 12, 2020Aspirant
No, there was nothing special/different now.
Looking at the log also only one of the 6 volumes I had before seemed not to be deleted completly and was waiting for the encryption key. All other 5 volumes have been deleted correctly.
