r00b
Aug 05, 2020Aspirant
RN428 - Waiting for encryption key but no encrypted volumes available
Hi together, some time ago I had an issue with my encrypted drives (encryption key wasn't found although it was on the pen drive). As a result I deleted all volumes and created new ones without e...
- Aug 11, 2020
Hi together,
I could fix the issue by doing the following steps:
- check systemd-journal.log to see which volume is causing the problem
- delete volume
- create new volume with the same name and encryption enabled
- delete new volume
- create new volume with the same name without encryption
(probably it's not necessary but I've done a reboot between each step)
Now the system boots up without asking for an ecryption key.
BR,
Robert
Sandshark
Aug 12, 2020Sensei
For the benetit of others, and Netwear if they find this is a bug, was there anything different in the way you deleted the re-created encrypted volume than the way you originally did it other than the fact that the encryption key for it was now available?
r00b
Aug 12, 2020Aspirant
No, there was nothing special/different now.
Looking at the log also only one of the 6 volumes I had before seemed not to be deleted completly and was waiting for the encryption key. All other 5 volumes have been deleted correctly.
