larsgorm
Dec 24, 2011Aspirant
RND 2120 vs. MS 2120
Hi there. I hope somebody can help me on this. I´ve just bought the RND 2120 (haven´t plugged it in yet), and here afterwards I see that there´s another budget model, the MS 2120. Can anyone tell me t...
JarnoG
Dec 25, 2011Guide
you can use your Duo to set up a Firefly server, iTunes is then able to see that and use it to play music from. After that you can sync your mobile devices via the PC/Mac running iTunes.
As far as I know, Airplay streams whatever is playing in iTunes, so you would be able to play the music on your NAS via iTunes on your Airplay-capable devices.
