larsgorm's avatar
larsgorm
RND 2120 vs. MS 2120
Hi there. I hope somebody can help me on this. I´ve just bought the RND 2120 (haven´t plugged it in yet), and here afterwards I see that there´s another budget model, the MS 2120. Can anyone tell me the major differences on these 2?
Should I have bought the MS 2120 instead?
(I will primarily use a NAS for network-storage of my iTunes library and photo library - and use it as a back-up device).
Thx for answer:-)
  • Thank you very much for your advices mdgm. I think I will return my RND 2120-100 and buy the Ultra 2 instead. By the way - can I use Photos II on the Ultra 2?
  • larsgorm wrote:
    ...By the way - can I use Photos II on the Ultra 2?
    Yes, you can use any x86 add-on.
ProSupport for Business
