AndyPC
Jan 27, 2017Aspirant
RND-4000-200EUS - almost Almost working
Hi there, just picked up 2 of these with a fault (I think). When you plug the power lead in (with no drives present), the unit lights the power button, and starts going through a block progress bar, ...
- Jan 28, 2017
Actually, ended up buying a power supply and adapter. Could have bought a power supply with 4-pin on the end, but wanted the flexibility of using the power supply elsewhere should the problem not be the power supply.
AndyPC
I forgot to mention, I haven't any drives to put into the unit yet, and it wasn't connected to either USB or ethernet, so could that also be an issue? If it is the power supply (the external brick, I presume), does anyone know of somewhere reasonable to obtain a replacement (I heard on one forum that some synology power supplies are compatible)?
Jan 27, 2017Guru - Experienced User
It should have stayed powered up.
- AndyPCJan 27, 2017Aspirant
So, what would you suggest, capacitor check inside for blown electrolytic capacitors and replace as necessary, or adaptor replacement?
- AndyPCJan 28, 2017Aspirant
In case it helps anyone else, this is what I'm going to try:
In the UK of course!
Opinions?
