AndyPC
Jan 27, 2017Aspirant
RND-4000-200EUS - almost Almost working
Hi there, just picked up 2 of these with a fault (I think). When you plug the power lead in (with no drives present), the unit lights the power button, and starts going through a block progress bar, ...
- Jan 28, 2017
Actually, ended up buying a power supply and adapter. Could have bought a power supply with 4-pin on the end, but wanted the flexibility of using the power supply elsewhere should the problem not be the power supply.
AndyPC
Jan 28, 2017Aspirant
FramerV
Jan 29, 2017NETGEAR Employee Retired
Hi AndyPC,
Thank you for sharing your resolution and/or workaround. We appreciate your contribution to the community.
Feel free to post any suggestions, questions, recommendations or anything about your NAS that you think needs attention or will help others.
