dkf20
Sep 02, 2016Follower
RND4000 NV+ Power Supply Options
Hi - new to the community but am in desperate need of some help The power supply on my NV+ has gone and ive called netgear support - apparently they do not have any left Can anyone recommend...
Sep 02, 2016Guru - Experienced User
You should confirm that this a v1 (4.1.x firmware), as that makes a difference here. http://www.rnasguide.com/2012/01/09/how-to-tell-whether-i-have-a-duo-v1-or-duo-v2-or-nv-v1-or-nv-v2/
A v1 seems most likely (I'd guess that support still has v2 PSU spares worldside). Assuming a v1, I think the SeaSonic 250 watt sfx supplies are the ones you want. But you will need to modify ATX pinout on the supply. Here's a link: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf
Though it's ugly, you can also get a cheaper ATX supply and keep it outside the unit (since it won't fit). You might need cable extensions in that case (and you could then modify the extension cable instead of the supply itself). Probably not a good long term solution, but if the goal is simply to offload the files on the NAS then it might work.
Netgear support can also assist you in migrating data to a new OS 6 NAS. You will need temporary storage (e.g., usb drives) to offload the data to. http://kb.netgear.com/app/answers/detail/a_id/29876
JennC
Sep 02, 2016NETGEAR Employee Retired
Hello dkf20,
If you are referring to the NV+ v1 that has 4.1.x FW version, support center in Australia ran of stock of this power supply unit already and will no longer restock it because this unit reached EOL status a long time ago. By the way, RND4PSU1 is the model number of the power supply in case you try to look for it online, there is a chance of getting one from online resellers.
Welcome to the community!
