dkf20
Sep 02, 2016Follower
RND4000 NV+ Power Supply Options
Hi - new to the community but am in desperate need of some help The power supply on my NV+ has gone and ive called netgear support - apparently they do not have any left Can anyone recommend...
MrBadger
Nov 19, 2016Aspirant
Going through the same pain myself. I just ordered one from the UK here: http://www.evercase.co.uk/PowerSupplyUnits.htm#ReadyNASPSU. It's listed as compatible and after I ordered it I saw this same link listed in another similar post.
Nov 21, 2016Guru - Experienced User
If you modify the pinout a little you can get much cheaper supply. That's what sandshark's link is about.
- MrBadgerNov 21, 2016Aspirant
Yeah, will I have what I thought was safe data. I really only get one shot at this and so I'm willing to pay extra to make sure it has the maximum chance of success.
