dkf20
Sep 02, 2016Follower
RND4000 NV+ Power Supply Options
Hi - new to the community but am in desperate need of some help The power supply on my NV+ has gone and ive called netgear support - apparently they do not have any left Can anyone recommend...
Nov 21, 2016Guru - Experienced User
If you modify the pinout a little you can get much cheaper supply. That's what sandshark's link is about.
MrBadger
Nov 21, 2016Aspirant
Yeah, will I have what I thought was safe data. I really only get one shot at this and so I'm willing to pay extra to make sure it has the maximum chance of success.
- FramerVNov 21, 2016NETGEAR Employee Retired
Hi MrBadger,
Safest would probably be to get the model number of PSU provided by JennC.
- MrBadgerNov 22, 2016Aspirant
JennC being...?
- StephenBNov 22, 2016Guru - Experienced User
MrBadger wrote:
JennC being...?
The mod who replied earlier in the thread ( https://community.netgear.com/t5/Using-your-ReadyNAS/RND4000-NV-Power-Supply-Options/m-p/1134947/highlight/true#M115088 )
Sandshark just didn't realize that you weren't the original poster.
