vcsnj
Sep 08, 2012Aspirant
RNDP4000 Problem with FTP Directory Listing
Hello everyone,
I log in with my FTP client (in this case FileZilla) and everything goes through but it never lists the directory. User name and passwords correct. Port forwarded to RNDP4000 correct. Shares have myself and my group both assigned with read/write permissions. When trying to FTP in from either outside or a computer right next to the box I get the following:
Status: Resolving address of XXXXXXX.dyndns.org
Status: Connection established, waiting for welcome message...
Response: 220 ProFTPD 1.3.3c Server (NETGEAR ReadyNAS) [74.102.103.93] (not sure where this IP is but it's not my location)
Command: USER XXXXX
Response: 331 Password required for XXXXX
Command: PASS *******
Response: 230 User XXXX logged in
Command: SYST
Response: 215 UNIX Type: L8
Command: FEAT
Response: 211-Features:
Response: MDTM
Response: MFMT
Response: TVFS
Response: UTF8
Response: AUTH TLS
Response: MFF modify;UNIX.group;UNIX.mode;
Response: MLST modify*;perm*;size*;type*;unique*;UNIX.group*;UNIX.mode*;UNIX.owner*;
Response: LANG en-US*
Response: PBSZ
Response: PROT
Response: SITE MKDIR
Response: SITE RMDIR
Response: SITE UTIME
Response: SITE SYMLINK
Response: REST STREAM
Response: SIZE
Response: 211 End
Command: OPTS UTF8 ON
Response: 200 UTF8 set to on
Status: Connected
Status: Retrieving directory listing...
Command: PWD
Response: 257 "/" is the current directory
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (74,102,103,93,234,129).
Command: MLSD
Error: Connection timed out
Error: Failed to retrieve directory listing
Any assistance would be greatly appreciated!
Command: USER XXXXX
Command: SYST
Command: FEAT
Response: MDTM
Response: MFMT
Response: TVFS
Response: UTF8
Response: AUTH TLS
Response: PBSZ
Response: PROT
Response: SIZE
Response: 211 End
Status: Connected
Command: PWD
Command: TYPE I
Command: PASV
Command: MLSD
- StephenBGuru - Experienced UserAre you also forwarding the passive ports in your router? The NAS is advertising port 60033 in your log "Response: 227 Entering Passive Mode (74,102,103,93,234,129)"
Also, your masquerade address (set in the NAS) is the same as your public IP address (which is the 74.x.x.x. address in your post). For some routers, you need to connect using the local IP address (often 192.168.x.x) when on the local LAN. If your router happens to require that, you need to set the masquerade to the local IP address. With FileZilla, setting the masquerade that way still lets you connect over internet. - vcsnjAspirantYup that was it. Never realized my old IP was listed under "Services" and then "Standard File Protocols"
Thanks for your help!!!!
