refles
Aug 06, 2012Aspirant
RNDP6000-200NAS (Pro 6) - sizing question
hi all, I just recently purchased the Pro6 model. I've been scanning this forum for the last few days and trying to find out what my total HD size should be under X-Raid2. (there should just be a ca...
mdgm-ntgr
Aug 06, 2012NETGEAR Employee Retired
Yes you can move to the latest firmware direct. So you just have the 2 3TB disks installed? For that your space looks right. You'd by default (unless you selected otherwise in RAIDar on setup) have 10GB reserved for snapshots. There would of course be overheads etc. and a 4GB OS partition.
