jeffyd
Oct 23, 2017Aspirant
RNDU2000 Power Supply Issue
I own an out of warranty RNDU2000 that has been experiencing 'V+12 power is out of normal range' issues, and the pwer supply is starting to fail.
I notice that at the back of the unit is an unknown port marked "P" that has five male pins in parallel that I assume is for an external power supply. If this is for an external power supply, what sort of connector is that? Can someone recommend a replacement external power supply? Or perhaps a source for a replacement chassis.
I do not wnat to upgrade to a new unit, as I am quite attached to the stability of the older OS
Are you sure that it's 5 pins (not 4)?
I'm suspecting you are looking at the serial output. That lets you see the console output - it isn't for power.
Normally it'd be covered with a sticker. There's a photo with it highlighted here:
