NasMan_AU
Dec 10, 2017Aspirant
RNDU6000 (ReadyNAS Ultra 6) – Frontview not accessible
Hello everyone and appreciate any help at all. Have used this forum a lot over the years as I have owned the above ReadyNas since 2012. The problem is esentially that all access to front view has s...
- Dec 10, 2017
Your 4GB root partition inodes were fully used. You should install the Toggle ReadyDLNA CacheDir add-on so that the ReadyDLNA cache directory is changed to be on the data volume. Otherwise this problem will quickly come back.
mdgm-ntgr
Dec 10, 2017NETGEAR Employee Retired
NasMan_AU
Dec 11, 2017Aspirant
Thank you Mdgm,
I cannot thank you enough your response was so fast and your service fantastic. Your suggestion to install toggle_ReadyDLNA CacheDir add-on was awesome and has now fixed the problem permanently. For those reading this mdgm still had to remote to my nas and fix the problem as described above. For anyone else looking for this updated DLNA add-on that moved my cache to my data directory, it is found here https://community.netgear.com/t5/Using-your-ReadyNAS/ReadyDLNA-OS-Partition-Usage/m-p/829401#M11295
Once again mdgm your a champion bloke and if you are ever in AUS I owe you a beer.
Cheers!
