btaroli
Apr 07, 2014Prodigy
ROS 6, OpenSSL, and package updates?
No sooner do I read this evening that Fedora and others a re quickly working to get OpenSSL 1.0.1e out to fix the latest TLS bug that I log into my 516 to see what version it's running. Oh my, 1.0.1e....
arnomc
Apr 10, 2014Aspirant
Here is what I did for my OS 6.1.6 on a legacy atom (amd64). Thanks especially goes to MueR, fastfwd & super-poussin. A disclaimer : if you are unsure of anything ask the gourous here on the forum, or have a look on : http://www.siteground.com/tutorials/ssh ... leting.htm
note: Please tell if you find any mistake or if something wasn't clear.
STEP 0: checking what you have and if you really need to do anything at all :
STEP 1: 'upgrading' openssl to deb7u11 (note that it would be different for other hardware or other readynas OS version), and maybe restarting apache & ssh.
STEP 1bis: verify
STEP 2: do the same for libssl (eventually check with dpkg -l | grep libssl), and restart apache2 & ssl :
STEP 3: via web interface go to System>Settings>Services, click on HTTPS & change the name in order to regenerate the certificates. Then delete the keys in /etc/ssh/ (ssh_host_xxxx files), & delete also files in /root/.ssh . Optional : after deleting with the rm command, check with the ls command (just to be sure).
STEP 3bis: some people could need to do this (if they have a mac) : http://blog.tinned-software.net/ssh-rem ... s-changed/
STEP 4: -> REBOOT your NAS
then CHANGE your root password only after you finished the whole process (there is no way to tell if the keys were not leaked). Final check on a test tool http://filippo.io/Heartbleed/
updated 20th June 2014 : openssl_1.0.1e-2+deb7u5_amd64.deb changed for "deb7u11" (dated 4 June 2014) and libssl1.0.0_1.0.1e-2+deb7u6_amd64.deb for "deb7u11".
cf : https://security-tracker.debian.org/tra ... -2014-0224
root@NAS:~# dpkg -l | grep openssl
ii openssl 1.0.1e-2+deb7u3 amd64 Secure Socket Layer (SSL) binary and related cryptographic tools
root@NAS:~# openssl version -b
built on: Mon Jan 6 19:32:28 UTC 2014
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/openssl_1.0.1e-2+deb7u11_amd64.deb
dpkg -i openssl_1.0.1e-2+deb7u11_amd64.deb
STEP 1bis: verify
ii openssl 1.0.1e-2+deb7u11 amd64 Secure Socket Layer (SSL) binary and related cryptographic tools
wget http://security.debian.org/debian-security/pool/updates/main/o/openssl/libssl1.0.0_1.0.1e-2+deb7u11_amd64.deb
dpkg -i libssl1.0.0_1.0.1e-2+deb7u11_amd64.deb
service apache2 restart
service ssh restart
root@NAS:~# ls /etc/ssh/
moduli ssh_host_dsa_key ssh_host_ecdsa_key.pub
ssh_config ssh_host_dsa_key.pub ssh_host_rsa_key
sshd_config ssh_host_ecdsa_key ssh_host_rsa_key.pub
root@NAS:~# rm /etc/ssh/ssh_host_*.pub
root@NAS:~# rm /root/.ssh/id_rsa.pub
root@NAS:~# rn_shutdown -r
