matt_s
Oct 31, 2012Aspirant
Rsync and scp performance
I have just bought a Readynas 4 ultra, I will now transfer 2,5 tb of data from my old Qnap NAS. Both are connected to a Netgear gigabit router. I started a rsync job to move the data from the Qnap to the Readynas, it is going awfully slow. My estimation is 10 mb/sec or less.
I also did a scp test between the two and got 3 mb/sec?? 30 minutes for a 5gb file.
I thought it would be faster over a local gigabit network??
- mdgm-ntgrNETGEAR Employee Retiredscp has overheads for the security. Rsync is very resource intensive and quite slow for full backups. Using another protocol such as NFS is much quicker for full backups.
- matt_sAspirantYou mean by mounting a share on the Readynas and copying that way? Ok, will try that!
- matt_sAspirantStopped the rsync job and are now copying through NFS share, you don't get transfer speeds when copying though so I don't really know how fast it goes..
- matt_sAspirantThe copy speed is now about 8mb/s, this is gonna take a while. Don't know what the bottleneck is here...
- StephenBGuru - Experienced Usermb/s or MB/s (bits or bytes)?
- matt_sAspirant8 megabytes per second
- StephenBGuru - Experienced UserWell I guess the main question is whether you are better off letting it run to completion, or stopping the transfer and troubleshooting. You're getting 700 GB a day (more or less). If the total transfer time will be 2-3 days, you are probably better off letting it finish than stopping/starting yet again.
I'd expect it to be faster (though I have a pro, not an ultra). Have you ever measured the transfer speed of the QNAP?
