bedlam1
May 30, 2017Prodigy
Rsync Backup job NAS to USB drive suddenly displaying strange behaviour
The backup job in question has been running flawlessly 3 times a day for the last year.(alongside a similar job which is not mis-behaving) The only change I have made since this began is installing ...
- Jun 22, 2017
Did you check the permissions and owners for these particular MP3s? Right-click in file explorer, etc...
bedlam1
Jun 22, 2017Prodigy
I made changes to permissions/access in an effort to spark something, it initiated a resync,having now run the backup again I am still getting the same errors.
However, I have also run ViceVersa Pro to compare the data version and the backup data version which confirms they are an exact replica
So I can only conclude the errors showing up are false
Jun 22, 2017Guru - Experienced User
Well, the error didn't say that the rsync copy failed. It said that rsync couldn't set the permissions to match the source.
So I think the errors are likely real, but comparing the files would still show them to be identical.
You could try resetting the permissions on the share that holds the MP3s.
- bedlam1Jun 22, 2017Prodigy
Did that this morning.....caused a resync, but no change to the backup job results log
- StephenBJun 22, 2017Guru - Experienced User
Thanks for the interest StephenB
Changed the owner of the whole Music share to Admin (it was Guest) and File Access to Users (it was guest), deleted the backup "Music" and ran the backup job again, no change. I think I will just live it until I have time to check the Windows Permissions/Ownership fully, particularly as I have a very simple Home setup of which I am the only user.
- bedlam1Jun 24, 2017Prodigy
Spent some time on Permissions in Windows Explorer today and made some changes.
Deleted the whole Music Backup dataset, ran my Rsync Backup job, on viewing the log there are now no "errors" shown.
Not sure which change I made resolved the issue but many thanks to StephenB for the pointer
- StephenBJun 24, 2017Guru - Experienced User
Glad you got it fixed.
- bedlam1Jun 27, 2017Prodigy
I spoke too soon, random ALC messages are back in the Backup log, the job completes, the Backup data is a complete mirror of the data.
Clearly something is not right either in Rsync or Win 10.
Am just going to ignore it
- SharpyJun 27, 2017Aspirant
How did you solve this problem I'm having the same problem
And my backup sizes Dont match the source sizes so I'm assuming that these files didn't copy
