gjenkins87
Jun 08, 2017Aspirant
Rsync backup problem using dyndns hostname
I have two readyNAS drives, one at work and one at home, they have both been working fine but I wanted to put a larger drive in the one at home so I started again with setting up my backups. When...
gjenkins87
Jul 25, 2017Aspirant
Correct Stephen,
Although earlier today I adjusted the MTU settings on the NAS to match that of the router , which was 1500 but since the switch to fibre and PPPoE the MTU is now 1492 ( I guess due to an extra 8 bits of network overhead?).
Anyways, since this change I have not been able to access the local NAS admin page, the drive is sitll working and I can access all the folders on it, I just don't want to reboot it or factory reset or anything while people are working.
i'm considering making a completely separate backup and starting from scratch with both drives again...
Jul 25, 2017Guru - Experienced User
gjenkins87 wrote:
Correct Stephen,
Well, 8 bytes. The overhead is the PPPoE part.
Did you make that change on the local (office) NAS or the remote NAS?
- gjenkins87Jul 25, 2017Aspirant
I made that change on the local NAS drive, i can still teamview into the remote one via my computer at home.
I can't think why that would have upset it but then it has always been slow and temperamental.
- Mar 14, 2019Retired_Member
