interested
Sep 08, 2011Tutor
RSYNC downgrade or upgrade ???
Hi. What is the right way to downgrade or update RSYNC ??? Becouse of some problems I would like to downgrade to RSYNC 3.0.6 apt-get remove rsync ( ver. 3.0.8 ) apt-get install rsync ..... ...
mdgm-ntgr
Sep 09, 2011NETGEAR Employee Retired
You could compile Rsync 3.0.6 from source. I don't know if NetGear's makes any modifications to Rsync or not to get it to work nicely on the ReadyNAS. Rsync 3.0.6 is found in the GPL for RAIDiator x86 4.2.11. See http://www.readynas.com/gpl
