interested
Sep 08, 2011Tutor
RSYNC downgrade or upgrade ???
Hi. What is the right way to downgrade or update RSYNC ??? Becouse of some problems I would like to downgrade to RSYNC 3.0.6 apt-get remove rsync ( ver. 3.0.8 ) apt-get install rsync ..... ...
mdgm-ntgr
Sep 09, 2011NETGEAR Employee Retired
Seeing my ReadyNAS units are in production use, I don't want to break them. It shouldn't be very hard to compile. There is a README file in the Rsync-3.0.6 folder explaining what needs to be done.
Just had a look and here's what you need to do
You should see the binary of rsync you just built. Assuming it's called "rsync", I think you'd need to do:
EDIT: would suggest following WhoCares' expert advice. Much better than what I suggested doing.
apt-get update
apt-get install build-essential
cd /path/to/rsync-3.0.6
configure
make
ls -la
cp -f rsync /usr/bin/rsync
