interested
Sep 08, 2011Tutor
RSYNC downgrade or upgrade ???
Hi. What is the right way to downgrade or update RSYNC ??? Becouse of some problems I would like to downgrade to RSYNC 3.0.6 apt-get remove rsync ( ver. 3.0.8 ) apt-get install rsync ..... ...
WhoCares_
Sep 09, 2011Mentor
As another workaround one could grab a copy of the older GPL sources archive and compile the rsync version found in there using the "dpkg-buildpackage" utility which would produce a .deb file that can be installed using "dpkg -i {name of .deb file}". This would have the advantage of the libraries being used by rsync getting replaced, too.
-Stefan
-Stefan
