interested
Sep 08, 2011Tutor
RSYNC downgrade or upgrade ???
Hi. What is the right way to downgrade or update RSYNC ??? Becouse of some problems I would like to downgrade to RSYNC 3.0.6 apt-get remove rsync ( ver. 3.0.8 ) apt-get install rsync ..... ...
interested
Sep 13, 2011Tutor
TNX to user WhoCares which has compiled rsync 3.0.7, here is a solution:
1. I did stop the RSYNC in frontview, under SERVICES > STANDARD FILE PROTOCOLS
2. with program like putty I connected to my NAS using SSH
3. write the the following commands:
Code:
wget http://whocares.de/rpro/rsync_3.0.7-1~bpo50+1_i386.deb
dpkg -i rsync_3.0.7-1~bpo50+1_i386.deb
4. start RSYNC again, , under SERVICES > STANDARD FILE PROTOCOLS
5. do the backup job
After all, the backups under 4.2.19 working again :D :D :D
Code:
