Digital999
Sep 18, 2016Luminary
Rsync email when job does not start
We had a disk usage mistake -- most of the available data space was used by an errant application.
Because of the low disk space circumstance it seems that Rsync 'canceled' scheduled backups -- most likely before they started because of lack of disk space.
Well we found and fixed the errant application and then discovered that all of the backups for the past week or so had not been completed and we did not receive any email notification. Email notification was set in the Options area of Rsync job setup. My guess is that the disk space was not available and the job never started and thus there were no errors to report.
Is there a way to get notified when a job does not start -- something that we could rely on to highlight the backup job not starting?
- JennCNETGEAR Employee Retired
Hello Digital999,
Unfortunately, there is no setting on the NAS that will get you notified if the job has not started as there is no alert when there is no action. I guess you may need to just check the logs from the admin page. Please see How to diagnose backup job failures on a ReadyNAS OS 6 system article.
- Digital999Luminary
Thanks for the confirmation of our hunch.
Now picture 53 different sites and several backup jobs per site each day. Checking logs is not a viable solution.
In most OS environments when a timer fires that is considered an action. If the timer fires off a job sequence and that job encounters a problem then an exception should be thrown by the job's environment-- again another action.
This is an area that should be improved. Please consider it for the next release.
Hello Digital999,
I guess you can also try suggestion this at idea exchange board Adding kudos to the ideas will help as development team will be reviewing the post that has the most kudos for considering it to add to the product's future functionality.
