msd's avatar
msd
Luminary
Oct 11, 2014
Rsync fails - How to Reset Permissions on a USB Drive?
Hi,
ReadyNas 312 Firmware 6.1.9
Rsync fails due to Error = failed: Read-only file system (30) (on USB drive) Silly part is the original backup was using Rsync however when I plug the USB drive back in Rsync fails due to Read only permissions.
How do I reset the File/Folder permissions on a USB drive, The "Reset File Access" area is not available on USB drives as the Settings -> File Access screens are blank.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Well I think the OS6 behaviour is better then.
    If a filesystem on the USB disk has errors there could be problems with the backup which is something you want to know about.
    Your welcome. Yes it is going well.
  • Personally I'd rather have a system that has greater sensitivity to errors so that I can detect a problem before it becomes too big to fix easily. It seems in this case that is exactly how OS6 has behaved.
    Perhaps consider that OS4 is inferior in that it failed to detect that there was a small problem with the destination disk?
    Edit: mdgm made similar point, didn't see post before I submitted mine.
  • Mmm well, if it was really good, it would report the error rather than just failing due to a single disk space error (caused by itself)! i am only writing this (not to have the last word) but as a suggestion..........perhaps for the OS6 OS to have a method of Checking i.e. a built in scandisk for USB drives, Food for thought.
    Cheers
ProSupport for Business
