JeWe
Jan 09, 2013Aspirant
Rsync hangs
Hi to all, I try to rsync directories to my ReadyNAS 3100, files to be synced are on Ubuntu 12.04LTS (from Ubuntu to ReadyNAS). The backup job is configured with user and password, no SSH is set. T...
Jan 09, 2013Guru - Experienced User
Odd. Did you check which versions of rsync are running on both platforms? My pro has rsync 3.0.9 protocol version 30.
Also, did you try initiating the sync from the Ubuntu system? (with rsync enabled for the Readynas share...)
