Siyfion
Sep 19, 2013Aspirant
Rsync just hangs..
So I have three shares on a ReadyNAS 3200 that I'd like to sync with a ReadyNAS Pro 4 which is used as an in-house backup, before the data is eventually backed up onto external HDDs and removed off-si...
mdgm-ntgr
Sep 19, 2013NETGEAR Employee Retired
It's normal.
If you look at the logs or do
You will see that a lot of RAM is used for caching to improve performance. The memory will be freed up if needed for other tasks.
# cat /proc/meminfo
