Earl0101
Sep 03, 2013Aspirant
rsync path limitation?
The first time trying to set up rsync between two NAS on a local network. Should be easy but am running into problems. Want to backup a Pro6 to a NVX. The Pro6 is assigned a static IP address of 19...
Sep 04, 2013Guru - Experienced User
To get rsync working, you need to enable the rsync service (network, standard file protocols) and you also need to enable it for the shares (via shares/share listing). You've done both steps? Maybe also try setting everyone to read/write access on both the source and the destination shares. use the "advanced options" tab for the share to reset/apply the access changes.
I also suggest trying a different file protocol (perhaps NFS) to see if that gives you different results.
