Sput1985
Jan 03, 2014Aspirant
Rsync to Freenas
Afternoon all Ive been trying for 24 hrs to get rsync copying my Duo to a freenas box I have installed, however nothing seems to by copying. I have a duo with raidar 4.1.6 I have turned the Rsy...
Jan 03, 2014Guru - Experienced User
The freenas is configured as an rsync server?
You can manually run the backup job by pressing the go button in the backup jobs list. That's probably a better way to get it working.
If you click on the help button when editing/creating a frontview backup job it provides you some useful examples.
You shouldn't put \\ before the host name for rsync backup jobs.
Also, the path name is case sensitive - I note that your windows access uses Data\Backups\ReadyNAS, but your path name is all lower case. In addition your slashes are backwards.
