Sput1985
Jan 03, 2014Aspirant
Rsync to Freenas
Afternoon all Ive been trying for 24 hrs to get rsync copying my Duo to a freenas box I have installed, however nothing seems to by copying. I have a duo with raidar 4.1.6 I have turned the Rsy...
Sput1985
Hi Stephen
I tried without the \\ before freenas and with data/backups/readynas/ and when I did test connection, I get connection failed, reverted to \\freenas and data/backups/readynas/ and connection succeeded.
On the freenas I have turned on the rsync service
I have also made a rsync module for the readynas given it read and write access, set it to use the root user and in the allow hosts I have put the readnas unc name
If I cancel a running job, to get the system status to change from "in progress" on the readynas I have been having to reboot. The job that is currently running is due to stop in 5 minutes, from the time settings I have given the job in frontview, I shall see if its staus changes, I expect that I shall have to reboot the readynas duo to get it to cancel/stop.
Reagrds
Sput
Reagrds
Sput
