Sput1985
Jan 03, 2014Aspirant
Rsync to Freenas
Afternoon all Ive been trying for 24 hrs to get rsync copying my Duo to a freenas box I have installed, however nothing seems to by copying. I have a duo with raidar 4.1.6 I have turned the Rsy...
Jan 03, 2014Guru - Experienced User
The stop time in frontview might not mean what you think. It is the end of the start window, not the time the backup job will end.
\\host is not needed on my duo (host works fine). None of my paths need slashes, so I can't test that.
Since you have rsync enabled for the shares, you can also try configuring the freenas to "pull" the data on its own. Frontview backup is then not involved (http://doc.freenas.org/index.php/Rsync_Tasks). Perhaps worth a try.
