Sput1985
Jan 03, 2014Aspirant
Rsync to Freenas
Afternoon all Ive been trying for 24 hrs to get rsync copying my Duo to a freenas box I have installed, however nothing seems to by copying. I have a duo with raidar 4.1.6 I have turned the Rsy...
Jan 03, 2014Guru - Experienced User
Create a frontview backup job with the destination set to "Remote Windows/NAS (Timestamp)" or "Remote NFS Server".
The path already works with Windows, so the first option will likely work. If the freenas destination is also configured to use NFS, then you could use the second option as well.
