azzkiker
Nov 01, 2013Aspirant
Rsync using SSH
Hello @ all, i want to use my newly bought Readynas RN104 to Backup some of my data from a Synology Diskstation DS2413+. To do this, i use rsync. The Readynas powers itself up, connects via rsync ...
xeltros
Jan 08, 2014Apprentice
to automate SSH login, the best option is to enable certificate authentication without password.
Another one would be to use expect in a script, I believe this could work. Both require to log in with SSH for configuration since the RN104 don't allow SSH configuration on the web interface but only ssh enable/disable.
By the way, Netgear keeps the option of denying support if SSH is enabled so if you run into trouble, depending on what problem you have and who you are working with they may require a factory reset.
