handy1
Nov 13, 2012Aspirant
Running a Time Sync Daemon to avoid NFS delays (Duo v.1.)?
I'm running 3 machines as well as a ReadyNAS Duo v.1, with the following systems: Linux (dual boots Win 7), PC-BSD & Mac OS/X 10.6.8. Due to a delay in the bootup of a new Linux install, I've come...
handy1
StephenB wrote: The Duo v1 lets you configure its time server (click in system in frontview, then clock).
handy wrote: My questions are, is there a method for setting up the ReadyNAS Duo v.1. to be the LAN time server? If so how?
If the unfortunate situation is that it is not possible, then the next question is how do you get the Duo to run a time sync daemon & accept one of the other machines as the time server?
There is also an old add-on for the v1 here: viewtopic.php?f=47&t=33964&p=187161&hilit=time+server#p187161 I am not sure if it still functions properly.
Thanks StephenB, your post was very helpful.
The frontview system/clock was set up correctly already (good luck I guess, I'd forgotten all about it). The link to WhoCares? , post was particularly helpful, as it is his add-on that I have installed. Just those few words on his post should be (those famous words) all that I need to know.
I'll post back one way or another in the future.
Thanks again.
