joe_schmo's avatar
Oct 12, 2016
Running defrag, losing 1GB a minute
I am running defrag for the first time in a while... and my free space is dropping like crazy.
Size  Used Avail Use% Mounted on
30T   28T  632G  98% /data
When this started, I had over 1TB of free space.  And it's going down now, about 1GB per minute.  Any ideas what is happening?  There's no one writing or adding data to the disks at all.
  • Also, there are no snapshots.  just wanted to clarify that up front so that can't be the cause.
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      Sounds like some of your files probably use CoW.
      Do you (or did you) have bit-rot protection enabled on any of your shares? This is separate to CoW but we link enabling/disabling bit-rot protection to enabling/disabling CoW.
      You should free up space before running volume maintenance on a volume that is this full.
      Which firmware are you running?
      What does your initrd.log look like?
      • joe_schmo's avatar
        joe_schmo
        Tutor
        my initrd.log:
        2014/01/15 14:52:32] Factory default initiated by button!
        [2014/01/15 14:52:47] Defaulting to X-RAID2 mode, RAID level 5
        [2014/01/15 14:53:03] Factory default initiated on ReadyNASOS 6.0.4.
        [2014/01/15 14:49:34] Updated from ReadyNASOS 6.0.4 to 6.1.5.
        [2014/01/15 16:02:20] Updated from ReadyNASOS 6.1.5 to 6.1.6.
        [2014/04/14 05:09:27] Updated from ReadyNASOS 6.1.6 (1389750453) to 6.1.7 (1396977042).
        [2014/05/24 11:33:24] Updated from ReadyNASOS 6.1.7 (1396977042) to 6.1.8 (1398980083).
        [2014/10/28 16:39:30] Updated from ReadyNASOS 6.1.8 (1398980083) to 6.1.9 (1409791183).
        I have Bitrot Protection (Copy on Write) enabled on all shares.  Not sure wha tyou mean by Bitrot being separate to CoW since its the same option.
        Firmware 6.4.2.
        What's the link between what I am seeing and bitrot?
ProSupport for Business
