joe_schmo
Oct 12, 2016Tutor
Running defrag, losing 1GB a minute
I am running defrag for the first time in a while... and my free space is dropping like crazy. Size Used Avail Use% Mounted on 30T 28T 632G 98% /data When this started, I had over 1TB o...
joe_schmo
Oct 13, 2016Tutor
I've identified 2 shares that have something...
In the Admin UI, it says ShareA Consumes 25.1TB, while du -h shows 24TB.
In the Admin UI, it says ShareB Consumes 2.8TB, while du -h shows 2.1TB.
For ShareA, I definitely don't need CoW, so, I am thinking of renaming it to ShareA2, creating a new ShareA with CoW disabled and then rsyncing the data over.
Would that work?
For ShareB, I think I want CoW on, because it's data that only gets addedd, not really edited... but if I did the same thing for that share as I did for ShareA, would I reclaim that missing 1.1TB?
Oct 13, 2016Guru - Experienced User
Let's review what CoW actually does:
CoW simply allows multiple versions of a file to use only one copy of the datablocks they have in common. In a snapshot context, if a 300 MB video file (for example) is in both a snapshot and the main share, then all the video data is held in common. So both files share all the datablocks, and only 300 MB of data is actually on the disk. This will normally be contiguous.
If you then edit a tagfield in the main file, then the datablock holding that tagfield has changed. So one datablock is different, all the others are still common. The file in the snapshot remains continguous. But in the main share, a new datablock is substituted for the original. The main share file is therefore fragmented into two (or possibly three) sections.
Now you run a defrag on the main share. The only way to defrag this video file is to replicate all the shared blocks - taking 600 MB of total space, instead of the original 300 MB.
Now the question which is unanswered:
Why are so many GBs of new datablock usage showing up in your system when you have no snapshots?
mdgm says "CoW can create them anyway" - he might well be right, but I don't see how. I think it is likely that you have snapshots that you can't see. This has happened to some users as a side-effect of software updates. I think you need to sort out if you have these hidden snapshots [or not] before you start making changes.
What do you see with
btrfs fi df /data/ShareA and btrfs fi df /data/ShareB
Also, do you see any paths containing .snapshots with
btrfs subvolume list /data
- joe_schmoOct 13, 2016Tutor
root@NAS:~# btrfs fi df /data/ShareA/ Data, single: total=28.45TiB, used=27.89TiB System, DUP: total=8.00MiB, used=3.43MiB System, single: total=4.00MiB, used=0.00B Metadata, DUP: total=279.00GiB, used=37.39GiB Metadata, single: total=8.00MiB, used=0.00B GlobalReserve, single: total=512.00MiB, used=32.00KiB root@NAS:~# btrfs fi df /data/ShareB/ Data, single: total=28.45TiB, used=27.89TiB System, DUP: total=8.00MiB, used=3.43MiB System, single: total=4.00MiB, used=0.00B Metadata, DUP: total=279.00GiB, used=37.39GiB Metadata, single: total=8.00MiB, used=0.00B GlobalReserve, single: total=512.00MiB, used=3.59MiB root@NAS:~# btrfs subvolume list /data ID 256 gen 1177180 top level 5 path home ID 259 gen 1462117 top level 5 path .apps ID 260 gen 7 top level 5 path .vault ID 266 gen 1030073 top level 5 path Backup ID 267 gen 1463111 top level 5 path ._share ID 268 gen 1463113 top level 5 path .timemachine ID 270 gen 1171396 top level 256 path home/joe ID 467 gen 1463441 top level 5 path ShareB ID 9341 gen 3032 top level 256 path home/userA ID 13841 gen 8115 top level 256 path home/userB ID 14001 gen 1463057 top level 5 path ShareC ID 14009 gen 563759 top level 5 path .purge ID 14010 gen 170284 top level 256 path home/userC ID 14011 gen 1029948 top level 5 path ShareD ID 14012 gen 1029937 top level 256 path home/userD ID 26342 gen 1177181 top level 256 path home/userE ID 34534 gen 1463441 top level 5 path ShareA ID 34535 gen 1463113 top level 34534 path ShareA/.snapshots
Wow, thanks for the detailed reply.... So I took your commands and ran them, see above.
I also started copying ShareB to a new Share. As I am moving the data, my free space is actually increasing.
Most shares have the same size between du -h and the Consumed colum in the UI. Some have larger consumed space. But one share has du -h showing 900GB more than the Consumed column. I get how it could be reversed, but that is odd.
- StephenBOct 13, 2016Guru - Experienced User
Great.
Is there anything in /ShareA/.snapshots ?
- mdgm-ntgrOct 13, 2016NETGEAR Employee Retired
You have a huge amount allocated to metadata. This suggests that you may well have had snapshots on this system at some point.
It could well be that the amount of metadata has been reduced greatly from what it once was (e.g. if snapshots were deleted) but a huge amount is still allocated to that.
Once you've freed up some space to get volume usage back down to e.g. 80-85% a balance could bring down the metadata allocation to a more reasonable level.
mdgm wrote:You have a huge amount allocated to metadata. This suggests that you may well have had snapshots on this system at some point.
Yeah, it's possible that I had snapshots way back, but I've had this NAS for almost 3 years, so it would have been a while ago.
From what it appears above, there's only 279GB of metadata. From what I can tell, I have 3TB of free space marked as allocated. For example, I've moved 1TB of data over to the new share (on the same partition), and I've increased my free space from 503GB to 942GB. The balance operation is not doing anything for free space.
I am kind of curious now, where the space that I am freeing up is allocated (as in, can I run a command or look somewhere to see it)?
Really appreciate all of the help on this from both of you.
A balance moves data and metadata around so that chunks are emptied and can be returned to unallocated space. That's the entire point of a balance.
On a very full system a balance may get stuck and not work so it is important to free up space first.
Allocated space is only a problem is the space on the data volume is fully allocated and data or metadata needs more allocated to it. - joe_schmoOct 14, 2016Tutor
How much space do you think I need to free up? The answer to that will dictate where I move data temporarily.
- StephenBOct 14, 2016Guru - Experienced User
I'd free up about 5 TB. That will bring you into the 80-85% range.
Longer term, you should consider either expanding the volume (e.g., 8 TB drives), adding on an EDA500, or possibly getting a second NAS for some of the data.
- joe_schmoOct 15, 2016Tutor
OK, so I am moving some data around to get the free space up... when I do a balance, from the numbers I posted above, I can expect to gain no more than 279GB of space though, right?
- mdgm-ntgrOct 17, 2016NETGEAR Employee Retired
A balance will move around both data and metadata. You'd expect some space to be returned to unallocated space from both of these.
- joe_schmoOct 19, 2016TutorAwesome. Final question... it appears that this is progressing at 1% per day. Any way to speed it up? Will freeing even more space make it go faster? btrfs balance status -v /data Balance on '/data' is running 1527 out of about 29508 chunks balanced (1528 considered), 95% left Dumping filters: flags 0x7, state 0x1, force is off DATA (flags 0x0): balancing METADATA (flags 0x0): balancing SYSTEM (flags 0x0): balancing
