iMike74
Jan 28, 2012Aspirant
Running Plex on a ReadyNAS Ultra Plus?
Hello I'm a complete beginner when it comes to NAS, but as I have a lot interest in movies and home theater I have decided to try to set up a NAS to run a media server. When looking into it, Netgea...
ChazzaDK
Jun 25, 2012Aspirant
Hello. Check this out http://forums.plexapp.com/index.php/top ... e-devices/ in a way defeats the idea of Plex just playing files whatever the format but if you can be bothered to prepare your rips then the Duo Ultra will work fine for you. There is no CPU use if the files are prepared properly.
