norcis
Jan 25, 2017Aspirant
Samba hangs
Hello, I have frequent problems accessing NAS through Samba in LAN (no domain, ten Windows 10 computers in Workgroup). When it works it works, but it freezes randomly, when opening/saving file o...
Jan 27, 2017Guru - Experienced User
Is the NAS using NIC teaming?
norcis
Jan 27, 2017Aspirant
yes, active backup mode enabled (so as I understand, using one of the network cards)
- StephenBJan 27, 2017Guru - Experienced User
Does anything change if you disconnect the second ethernet cable?
- norcisApr 11, 2017Aspirant
No
- jak0lantashApr 11, 2017Mentor
What do you do to recover access? Does it just come back on its own? If so, how long does it stay unreachable?
What's the usage of the RN2120? Bit rot protection enabled? Snapshots? Rsync backup jobs? Is it under load when the issue occurs?
Is the data volume healthy? Unbalanced? Metadata allocation? (Beginning of btrfs.log from the log archive you can download)
Do you use quotas? Is quota accounting enabled on the volume (Settings of the volume)?
