Mikko_Linna's avatar
Mikko_Linna
Samsung bluray + TV and ReadyNas Duo
Hi,
I've got ReadyNas Duo, Samsung bluray bdd5500 and samsung led tv ue40c8705. I'm trying to stream my movies from my nas with my bluray and my tv without any results. If I reboot the nas I'm able to see the nas with my bluray and I'm able to start to play a movie, but after 2 minutes it says nas is unblugged, which it isn't. After that I'm unable to see the nas unless I reboot it again and it goes through the same stuff. I can play everything from my nas with iPhone, iPad, MacBook Pro and with my pc's but not with anything that's got Samsung on it....
I've already updated firmwares on my bluray and on my tv. I updated nas firmware and readydlna to the newest ones. Readydlna does not show in installed add-ons however, is that normal?
What can I do??? This just is so irritating 'cause I upgraded my Netgear Stora to ReadyNas since it should be so much better, but Stora atleast worked flawlesly with my tv and bluray :evil:
Help me please!!!
  • is your blueray playing wired to network or are you using the samsung wireless adaptor?
    as i had simular problem using the samsung wireless adaptor on my tv,it would disconnect and stop me from watching my stuff now i use my sammy blueray player but its wired using ethernet to my router and i have 0 problems streaming now
  • Yes, I'm using the wifidongle. I noticed the same thing with my other tv that is connected with the ethernet cable that it works...but this set that I'm needing help with cannot connect with cable since I would have to use 30 meter long cable, whoch is not a good solution, I would use an usbharddrive instead then...
  • try loging into your router and changing your wireless channel,i was using my wireless dngle for a long time then 1 day had nothing but problems,i changed my wireless channel and then it was fine
ProSupport for Business
