chris_b1
Feb 08, 2012Aspirant
SATA reset
I recently started getting problems with my ReadyNAS Duo waking up – the boot process stopped soon after the start with the fans running fast, and needed a hard reboot to start. I raised a support tic...
Feb 08, 2012Guru - Experienced User
Have you looked at the SMART stats under health?
Seatools doesn't care about the format, so it can check the drives.
