chris_b1
Feb 08, 2012Aspirant
SATA reset
I recently started getting problems with my ReadyNAS Duo waking up – the boot process stopped soon after the start with the fans running fast, and needed a hard reboot to start. I raised a support tic...
PapaBear1
Feb 08, 2012Apprentice
SeaTools for Windows will not run properly to check a drive if it is connected via USB. It must be connected via an SATA port of the motherboard.
