chris_b1
Feb 08, 2012Aspirant
SATA reset
I recently started getting problems with my ReadyNAS Duo waking up – the boot process stopped soon after the start with the fans running fast, and needed a hard reboot to start. I raised a support tic...
PapaBear1
Feb 08, 2012Apprentice
Not in my opinion. I really haven't watched very closely that often. Currently my second NVX is doing it's weekly disk scrub with is basically a resync. Now it usually takes about 10 hours (starts a 4AM and finishes about 2PM). That calculates out to about 120MB/sec, but then it is an x-86 based unit with X-Raid2. Sunday night I lost a 1TB drive on my first NVX (mixed 2x3TB and 2x1TB) when I installed a spare and it went through the resync, it only took 6 hours, but that could be because it only did the 1TB layer.
If you don't have a spare SATA cable, you can temporarily use the one that normally goes to the DVD drive.
